pingspikes
Message 1 of 5
bt ping spikes
hello i have been having ping issue with bt fibre broadband
wired connection
Ping only spikes when any device is using streaming services or downloading files
ping jumps from 5ms to 200ms
first ping test without loading any streaming services
second with loading streaming services
4 REPLIES 4
Matt-S
Moderator-Retired
Message 2 of 5
Re: bt ping spikes
Hi @pingspikes,
Welcome to the Community and thanks for taking the time to post.
Sorry to hear that you are experiencing ping spikes.
Are you trying to game online and watch a stream at the same time?
Matt
pingspikes
Message 3 of 5
Re: bt ping spikes
hi @Matt-S
No I'm not streaming videos while I'm gaming.
It spikes when my household member are using stream services or me.
thanks
pingspikes
Message 4 of 5
Re: bt ping spikes
hi @Matt-S
thanks
jk494
Message 5 of 5
Re: bt ping spikes
Sounds the same as my fault. Search for FAST and do a speed check, whats the loaded latency?
The fault seems to be at the BT server end and the way it prioritises information, lots of postings on the community that all seem to be revolving around this common item.
