thomasmulhall
Message 1 of 2
bt smart hub port fowarding
Hi how can i do port forwarding in the new bt smart hub, since i am trying it but wont work, yet when i did the bt home hub it worked.
I am trying to get http and https working remotly.
I am trying to port forward to an znc on port 5000 but it isent working remotly, how can i do it please?
1 REPLY 1
Message 2 of 2
Re: bt smart hub port fowarding
Welcome to this forum.
Port forwarding does work on the home hub 6.
Please can you display the results from this page, so I can see the settings.
http://192.168.1.254/0000012803/gui/#/firewall/portForwarding
Its best to assign a static IP address manually on the cameras, and make sure they are outside of the home hubs DHCP range.
Make sure uPnP is disabled, as that can cause problems.
Use 192.168.1.1 to 192.168.1.63.
Here is an example screen from a HH6 that I manage, it shows a computer on 192.168.1.32, an IP camera on 192.168.1.31, and a NAS on 192.168.1.60.
