dougjard
Message 1 of 7
business hub wifi slow
Been having speed issues with new hub to laptop Am only getting 30mbs or so HH5 was double so had bright idea plug in ethernet cable Instant 72mbs So why wifi slow on two laptops? Speed varies from low teens to high 30s on a good day new hub in same place as previous hub 1m from laptop
6 REPLIES 6
Message 2 of 7
Re: business hub wifi slow
Are you a business user?
dougjard
Message 3 of 7
No home user
Son has just done speed check on ipad 13mbs! pointing to hum issue am going to try new channel
Message 4 of 7
Not sure if the business hub is the same as the home hub, but on the home hub these are the steps to take.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
If its like the home hub, then you only have a choice of three of the available 13 wireless channels, so if they are all congested, then you are stuck.
Message 5 of 7
Can you post stats from hub and the run btspeedtester and when first test completes run diagnostic test and post results remember must be done with Ethernet connection.
http://speedtest.btwholesale.com/
Message 6 of 7
@imjolly
@dougjard has already said that its fine on Ethernet, 72Mbs.
dougjard
Message 7 of 7
Speed test results
Download 32.78mbs
Upload speed 16.04
Ping 0.00
Log
Product name:
Business Smart Hub
Serial number:
+088315+NQ81793497
Firmware version:
SG4B1B008198
Firmware updated:
18-Sep-2018
Board version:
1.0
Gui version:
1.91.5
DSL uptime:
8 Days, 20 Hours 47 Minutes 17 Seconds
Data rate:
20.00 Mbps / 74.00 Mbps
Maximum data rate:
28536 / 83527
Noise margin:
15.3 dB / 8.4 dB
Line attenuation:
0 dB / 12.5 dB
Signal attenuation:
0 dB / 12.5 dB
VLAN id:
101
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
60 GB Uploaded / 98 GB Downloaded
Broadband username:
green-light@service.btclick.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTBHub6-WXH8
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTBHub6-WXH8-5ghz
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 2
Firewall:
On
MAC address:
28:9E:FC:A2:49:6F
Software variant:
Boot loader:
9.2.0
