Pete23
Message 1 of 21
can't connect to https: site
I recently change my website to be secure https:// but from my home network using BT HH6 I can connect to the new secure site it will only connect to the old unsecured http:// site,  However from my work laptop connect through the same wifi network & hub and through my companies network I can load the https:// site.
Using my mobile devices phone/tablet etc, these load the https:// site either through 3/4G or when connected to external wifi such as Starbucks etc. but again when I connect the device to my home network they route only to the old unsecured http:// site
20 REPLIES 20
albertj
Message 2 of 21
Re: can't connect to https: site
If you force your browser to load it over https:// does it redirect to http://?
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
Pete23
Message 3 of 21
yes it redirects to http://
albertj
Message 4 of 21
Do other devices on the same network load it over https?
Pete23
Message 5 of 21
No they all get routed to the old http:// site
albertj
Message 6 of 21
Would it be possible to post the URL of the site with this issue?
Pete23
Message 7 of 21
No problem the my BT HH6 routes through BT as athe ISP is cbfgolfsociety.co.uk
The new site I can reach from any other network other than my home network using the same device is.....
albertj
Message 8 of 21
Your site isn't configured for https:// correctly.
If I try and load it then I get taken to the http:// version:
And if I force my browser to go to https:// then I get this:
If I then go to https://, it says your SSL Certificate is invalid
This was in Chrome, but the same occurs in Firefox.
I would recommend speaking to your host about this, as I don't believe it is configured correctly.
EDIT: This was on a BT Connection, but as you say loading it over 3G (in my case Three), fixes the issue.
Message 9 of 21
I have found that it loads as https://cbfgolfsociety.co.uk without any problem in Chrome, Firefox, Opera and Edge.
Can you load other https sites without problems?
albertj
Message 10 of 21
An issue with HH6 maybe or BT DNS Servers? I loaded it over BT and had the same issue. I load it over 3G and it’s fine...
