Message 11 of 21
Re: can't connect to https: site
I get an SSL error using Google DNS
albertj
Message 12 of 21
Yep, I tried loading it over CloudFlare DNS (1.1.1.1) with no difference made. It still loads the old site without HTTPS
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
albertj
Message 13 of 21
I think it's an issue with IPv6. I ran your site through a SSL Server Test:
And I can't run your site through a speed tester (GTMetrix):
For IPv4, it seems fine: https://www.ssllabs.com/ssltest/analyze.html?d=cbfgolfsociety.co.uk&s=158.255.47.118
I would still recommend raising this with your host.
Pete23
Message 14 of 21
This can't be the case... I've just been out to a restaurant logged on to their network with my phone and no problem the https:// site comes up. Just got back home connected to  my home wifi BT ISP HH6 and the old http://site is loaded instead.
This has to be something local with the HH6.
Message 15 of 21
Try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds.
albertj
Message 16 of 21
The same issue occurs for me on a Smart Hub 6,  but when I go on a different network or 4G, no issues.
So I don’t think this would resolve it?..
Message 17 of 21
Definitely an IPv6 problem. If I disable IPv6 I can reach the site, if I enable it I can't.
albertj
Message 18 of 21
Thank you for confirming 😊
I tried doing this, but don’t think I disabled IPv6 correctly.
Pete23
Message 19 of 21
OK thanks solved....it was the IPV6 setting on my BT HH6.
Home>Advanced>IPV6>Configuation
Set ULA to enable
Set Allocation mode to Stateful
albertj
Message 20 of 21
What about people you who visit your website with IPv6, they will have this issue.
This isn’t a fix.
