Message 1 of 9
change hub password and generate new QR code
Can someone please explain, in simple terms, how I generate a new QR code once I have updated the password for my hub?
8 REPLIES 8
Message 2 of 9
Re: change hub password and generate new QR code
What QR code?
Message 3 of 9
I think you need to explain what your requirement is for a QR code. You can change the hub password any time without any need to generate a QR code
Message 4 of 9
We run a tearoom and have the qr code accessible so visitors can easily access our wi-fi.  Very old building with thick walls so cannot access mobile signals inside the building.
Anonymous
Not applicable
Message 5 of 9
Google "online qr generator".
Message 6 of 9
thanks. I'll give it a go.
Anonymous
Not applicable
Message 7 of 9
Also, if you have a recent Android phone, you can generate a WiFi QR code from the Settings page for your SSID.
Message 8 of 9
So you can! Never realised that.
Message 9 of 9
Wish I had seen this reply before I tried.  It sounds much simpler.  I did manage to do it though.
