is it possible to piggy back the ATC to the HH6 to extend the wifi range in my house, and, if so, can anyone advise me of the best way to do it please?
I have just found this on another old thread, and was wondering if this is still correct?
I don't know anything about the sky router but the genetral principle is the same for whatever router. You will need to give the sky box an IP address outside the DHCP range of the HUB such as 192.168.1.50, set the gateway to 192.168.1.254. Disable DHCP on the sky box and connect any LAN port on the Hub to any LAN port on the sky box either directly by Ethernet cable or by powerline adaptors.
Yep
I have my time Capsule connected to the Router via an Ethernet cable and then used the Airport Utility to configure the ATC as Bridge mode. You can also do the same without the Ethernet connection but obviously may have speed issues depending on the Wi-Fi signal (make sure you split the SSID on the HH so the 2.4GHz and 5GHz bands have different names).
