JOET13
Newbie
Message 1 of 6
connecting old deskjet 3050 j610
I am trying to connect my old HP printer to the wifi network, I have tried several times clicking the WPS button on the router and have set the printer to discover the new network with no success.
It would be good to get some advise and support on connecting this printer.
cheers
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: connecting old deskjet 3050 j610
What version of home hub do you have?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 6
Have you split the wiresless networks?
you may need to change the wireless mode from 1 to 2 or 3
JOET13
Newbie
Message 4 of 6
Hi Thanks for the fast response,
It is a BT smart hub2
JOET13
Newbie
Message 5 of 6
Thanks for the response, but I am sorry this is unclear to me what you mean? Change modes where?
Message 6 of 6
You can't split the frequencies on the SH2 but you can change modes in the hub manager > advanced settings > wireless.
You might be better setting the wireless passkey manually on the printer rather than using WPS
