DB13
Newbie
Message 1 of 2
devices conecting.
Hi I have changed and saved my password on my BT box
However the tenda system is still able to connect without the new password  Why
1 REPLY 1
Message 2 of 2
Re: devices conecting.
Is it the admin password you have changed or the wireless password?
The admin password stops access to the managment pages of the BT Hub and the wireless password stops devices connecting via wireless to the BT Hub.
see links
https://bt.custhelp.com/app/answers/detail/a_id/14110/~/how-do-i-change-the-wi-fi-password-on-my-bt-...
https://bt.custhelp.com/app/answers/detail/a_id/10990/~/how-can-i-change-the-admin-password-on-my-bt...
If your Tenda is connected via an Ethernet cable to the BT Hub changing the BT Hub's wireless password will not prevent the Tenda from connecting to the hub. It is not using the hubs wireless signal it is using Ethernet to connect to the hub and the Internet and then it broadcasts its own wireless signal which you connect to.
