If your Tenda is connected via an Ethernet cable to the BT Hub changing the BT Hub's wireless password will not prevent the Tenda from connecting to the hub. It is not using the hubs wireless signal it is using Ethernet to connect to the hub and the Internet and then it broadcasts its own wireless signal which you connect to.
