Message 1 of 9
dhcp request help
Hi can anyone help my router logs are just full of these requests ? And the WiFi keeps going down
8 REPLIES 8
Message 2 of 9
Re: dhcp request help
The 2 things are not related. My logs are also full of DHCP requests, no idea why or which device(s) they are coming from.
When you say wifi keeps going down, do you mean just the wifi or broadband?
Message 3 of 9
Thanks for the reply it’s being solid for 6 month but over the last few weeks Iv noticed several of my devices have gone off line door bell , gaps in Cctv recording and problems with the tv , the wired devices are fine as much as I can tell Iv tryed a hard reset and I don’t no what else I can try
Message 4 of 9
You could try changing WiFi channels.
Message 5 of 9
Seems odd. My SH2 is configured to sync my public IP with my DDNS provider and I see no DHCP request entries in my event log but I do see a stack of repeating DDNS updates
Message 6 of 9
It runs fine for say 12 hours after a reset then it will start dropping and disconnecting devices, Iv been sent a new sh2  but I really didn’t want to go through the trouble of reconnecting everything Cctv etc but think iam going to have to bite the bullet and do it 😔
Message 7 of 9
No problem, just make a note of the SSID and password of the router you're using now and set the new one to be the same, your devices won't know the difference
Message 8 of 9
Ok thanks great idea 💡 I’ll let you how I get on , it’s just WiFi the lan connections are solid so fingers crossed it’s the router.
Message 9 of 9
Did you get this sorted i have all the issues that you have stated  been tying to sort this for three months tried the technical help reboot better wireless chanel al the simple stuff, i beleive its a signal issue going to the hub that is causing the disruption
