sunshine12
Message 1 of 4
dsl settings
tp link vr2800
internet works, but i want to still know what are the optimum settings in the dsl settings
3 REPLIES 3
licquorice
Message 2 of 4
Re: dsl settings
There are no 'optimum' settings, if it works you have the correct settings. It wouldn't work at all with incorrect settings.
sunshine12
Message 3 of 4
Re: dsl settings
bit swap and SAR unselect or select?
licquorice
Message 4 of 4
Re: dsl settings
Select Bitswap 'On' although probably won't make any difference either way, SRA isn't supported on VDSL so irrelevant.
