Message 1 of 4
dual-band-wi-fi-extender-600-user-
hi have purchased the above item.am having problems with range.can i buy a long ethernet cable plug it it a Home Hub 3 plug the extender into socket then plug ethernet cable into extender.will this then give wireless in that room.seems a daft question but just want confirm b4 getting cable many thanks
3 REPLIES 3
Message 2 of 4
Re: dual-band-wi-fi-extender-600-user-
If its this one you have
http://www.shop.bt.com/products/bt-dual-band-wi-fi-extender-610-083530-BJ7Q.html
Then its unlikely to work if you plug in an Eternet cable from the home hub. The Ethernet port on it is for connecting devices to receive over WiFi  (Client Mode).
What you are looking for is something to act in Access Point Mode. You would be better off using something like this.
http://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Message 3 of 4
Thank you for your answer.yes this is the correct extender..mh daughter only wants to access ininternet on her phone by wifi.computer is already hard wired.so could you confirm that would work.my apologies after radi.g first post it was a bit vague
Message 4 of 4
Sorry that this would work using the 610 way or would I still be better getting yout so to speak
