Message 11 of 26
Re: error 403 searching the internet from bt.com homepage and bt yahoo email page
I have also tried BT search from this page and from BT home using FF and Chrome and working ok for me
gramps05
Message 12 of 26
Thanks John. Iam now using Google on its own
Message 13 of 26
From the error message I get I suspect its only certain IP addresses that are affected. Probably a new pool of addresses that haven't been added to the Google list of BT addresses. Just tried to force a change but unfortunately got the same one back!! Anybody else want to try changing their IP?
403. That’s an error.
Your client does not have permission to get URL /search?num=10&client=btportal&output=xml&ad=0&adrep=3&adlh=on&as_qdr=&adsafe=&oe=utf8&ie=utf8&adext=as1,l1,sr2&safe=low&channel=Test10,pef_Test10&q=bbc&start=0&adpage=1&ip=178.79.194.141&useragent=Mozilla%2F5.0%20(Windows%20NT%206.3%3B%20WOW64%3B%20Trident%2F7.0%3B%20MAARJS%3B%20rv%3A11.0)%20like%20Gecko from this server. (Client IP address: 81.155.xxx.x)
You do not have permission to send search queries from this IP address. Please login to the Google Admin Console and ensure that this IP is in your list of permitted IPs. Remember that it may take a few hours for a newly added IP address to become activated and able to perform queries. That’s all we know.
Guru
Guru
Message 14 of 26
It seems to be a temporary glitch.
I was getting the 403 google html error message using both BT and VM IP addresses
However now it seems to be fine for using both IP addresses.
The results should load in the URL http://search.bt.com/ rather than http://www.google.com/search
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 15 of 26
Still getting the error here. Its loading http://www.google.com/search
antonio1
Message 16 of 26
I'm getting this error as well. If i go onto a web search which is allowed, I can then substitute the search I want and it goes onto the site Ok. I am having the problem attempting to go to the lloyds bank site from the bt homepage
antonio
nannajan13
Message 17 of 26
I am also having the same problem, started yesterday and nothing I do seems to fix it. Hope BT sort this out quickly.
Dovershark
Message 18 of 26
I too have been having this problem for several days. I thought it was a problem with my laptop! Hope someone can come up with an easy solution.
Message 19 of 26
The extremely easy solution is to make Google your homepage.
Moderator-Retired
Message 20 of 26
Hi guys,
We have been working on this since Thursday with a very high priority. This currently only affects a small percentage of users, but we hope to have the issue resolved in the next 24-48 hours.
OlgaC
Community ModeratorOlga
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
