dang84
Newbie
Message 1 of 2
ethernet ports keep dropping out - business smart hub
Just had a new business smart hub installed, I can't connect to the internet through the ethernet ports on the back, it connects briefly and then drops out, does this over and over again.
Seems to be a common problem......................
Any ideas how to sort as I currently can't use the computer in my office for work!!!
1 REPLY 1
Message 2 of 2
Re: ethernet ports keep dropping out - business smart hub
This is a BT Residential forum. If you are a business user you need to post on the BT Business forum where you should get the relevant help.
https://business.forums.bt.com/
