iankerry
Message 1 of 6
fixed ip on new router
Hi
I need to have a fixed ip address as it is used in someones firewall to let me through and access an SQL database for the charity i work for.
But i am on BT residential.
And the usual DYNDns wont work (as i understand it) as there is not a fixed ip address that i can use, just a domain.
So my question is, is the fact that i can't have a fixed ip address to do with the BT home hub router? or the BT residential line?
In other words, I have a nice draytek router here, can i use that and get myself a fixed ip address?
many thanks.
ian
www.artsalive.co.uk
5 REPLIES 5
Message 2 of 6
Re: fixed ip on new router
BT do not offer fixed IP addresses on residential lines it has nothing to do with your router.
iankerry
Message 3 of 6
thanks.
sjonez
Message 4 of 6
As an alternative to moving to a business broadband package you could always use a VPN service that provides you with a private static IP (e.g. PureVPN) for when accessing the database. Cost is around $2 per month on top of the VPN (which is useful to have anyway)
iankerry
Message 5 of 6
Thanks very much, I'll check that out.
Ian
Jonkarra
Expert
Message 6 of 6
You could also speak to the charity and see if they could terminate a VPN on there firewall or other network equipment.
