Message 1 of 5
getting Home Hub 3 version b to work on another provider in another country
Hi there i bought a BT home hub 3 (version B) from a car boot sale in the UK a couple of years back, only cost a fiver so didnt break the bank - but i brought it back to Ireland with me and changed the VPI to 8 and the VCI to 35 and chose PPPoe and LLC and  and it locked onto my ADSL (g.DMT) absolutely fine - the only problem is when I put in our username vodafone@vodafone.ie and broadband as the password (which has worked on all my other modem routers) the BT home hub sayssomething about its not a recognised provider or something like that, have i no hope of using this modem/router then over here in Ireland? thanks for any help/workarounds.
4 REPLIES 4
Message 2 of 5
Re: getting Home Hub 3 version b to work on another provider in another country
the hub is locked to BT
Message 3 of 5
thanks but there is a selection in settings for using with a different internet provider and a non-bt customer ....
Message 4 of 5
nobody on the forum will post any unlocking of HH as mods will just delete it   try kitz forum
Message 5 of 5
thanks , will do
