jonew
Message 11 of 29
Re: had the hh4 less than a wk n went back to hh3
Will see what tech say next week but I agree a new router will probably be needed...
Any gd gaming ones out there?
satdudeuk
Message 12 of 29
Why dont you get your self a non bt brand router mate save your self and hasstle  and to  others there are some very good routers out there.
ironman123
Recognised Expert
Message 13 of 29
Or go even further,and use a Draytek,like I do.
Always online,no disconnections,good latency,and down/up always 74Mbps+/16Mbps+.:)
hippey
Expert
Message 14 of 29
They were tested by the community, I find the hh4 much better at handling multicast. I have tweeked a few settings and now seems to works with no issues.
jonew
Message 15 of 29
Multicast?
If you mean more items on one router then yh if there all 5band... my issue is with the 2.4ghz
NewtronStar
Expert
Message 16 of 29
If your not happy with the HH4 you can send it my way ! i'll make it work for me Smiley Wink
hippey
Expert
Message 17 of 29
No, multicast for BT Vision. My HH3 had some issues with the QOS for the streams.
The wireless side of the HH4 needed a little tweeking but now works fine. The 5g side distance is slightly less but that is expected. Overall a good router in my experience.
jonew
Message 18 of 29
The 2.4 range is extremely poor, I barely get a signal upstairs n youtube buffers alot unless im sitting next to the hh4.
5 band I have no issue at all.
Even tech said on the phone 2.4 has a poor range.
Still awaiting a call back from tech in exeter ..
Hh4 has fixed my gaming issue but for 2.4 wi fi is useless for me
Distinguished Guru
Message 19 of 29
What did you tweak on the wireless?
If not, I'll try again 🙂
jonew
Message 20 of 29
Was the hh4 tested whilst 5 band was in use and other 2.4 equipment in use also.??
Bt 4.0 laptop on 5 band auto connected whilst my iphone galaxy s3 n ipad wouldn't sync but when they did not even facebook would load.. constant loading icon would be displayed.
Youtube would buffer n im on 70mb speed.
Ive said before it might be a faulty router tho
