mrmagicmart
Message 1 of 17
help my Nat setting have gone to strict hh4
I'm pulling my hair out bt customer support is shocking. I have a xbox one nat was open. Now it's strict gaming not so good there no info on the home hub 4 plz can someone help
16 REPLIES 16
Message 2 of 17
Re: help my Nat setting have gone to strict hh4
Please check the notes on this link NAT Problems on games consoles and computers
lowei
Expert
Message 3 of 17
Turn any port forwarding or DMZs you have configured to off.
Set the xbox ip addresses to auto.
And turn UPnP on.
mrmagicmart
Message 4 of 17
Whats dmz no port forwarding set up ip address box is on auto but grayed out so can't change it even if I wanted to and how do I turn on upnp on as could not see it on setting on hh4
Message 5 of 17
Did you see on my link about the CG-NAT issue?
mrmagicmart
Message 6 of 17
No not yet as won't let me as I'm out and about I'm guessing it will be the same as I've been sent already ie won't have info on hh4 and nat setting
Message 7 of 17
No, its a totally different issue. Read it when you get home, its all explained there, and you can see if you are affected.
mrmagicmart
Message 8 of 17
Affected sounds bad hope there a fix will read when I get home thanks guys
Message 9 of 17
There is a fix, but until you can look at the page, and your home hub, you are not going to be able to tell.
mrmagicmart
Message 10 of 17
ive looked and still very confued dont take a lot lol ive looked at my home hub and the pic on ur site where it says broadband network ip adress it start off with 86.3numbers.2numbers.3numbers i belive its my ip adress when i checked it out on the web sites it was the same. if thats any help so doese that help?
