Message 11 of 17
Re: help my Nat setting have gone to strict hh4
So you are not on CG-NAT, which is a good sign. All I can suggest is that you recheck any port forwarding rules for the game you are playing, so you allow incoming connections.
It may be worthwhile resetting the home hub to factory default, then re-enter the port forwarding rules again.
lowei
Expert
Message 12 of 17
mrmagicmart
Message 13 of 17
how do i port forward and what ones do i need to do you have an dummys guide as im not up with all this do i need to change my ip addy to manual as well?
Message 14 of 17
The guide is linked to on the last post. You cannot fix your public IP address, as its a Dynamically Allocated by BT, and can change.
mrmagicmart
Message 15 of 17
Trying to port forward but am only getting 2 boxes up range from and translate there should be more boxes grr
mrmagicmart
Message 16 of 17
thank all ive opend some ports now says nat is open thanks everyone yay
Message 17 of 17
Excellent Smiley Happy
