raybh
Message 11 of 14
Re: home hub 6 wifi
I was the op and was happy with the advice I was given, as a factory reset didn't cure the fault I contacted BT online and what they did and said I reported above as someone else had posted
6605paull
Message 12 of 14
Re: home hub 6 wifi
What winds me up is you report a fault, then the usual line checks and then the fault gets passed to god knows who to call you back within 48 hours, who then if they phone back does exactly the same line check to tell you what you already know. Round and round we go. Should have stayed with SKY for the TV services as they at the moment do not rely on the phone line/hub 6 actually working. Live and learn.
gg30340
Message 13 of 14
Re: home hub 6 wifi
None of which has anything to do with this thread.
If you have a specific problem you could try starting your own thread stating what the problem is and what if anything you have already tried to resolve it and you may be given some help/advice by forum members.
6605paull
Message 14 of 14
Re: home hub 6 wifi
OK point taken, thanks for ponting that out very useful
