rustygoat
Message 1 of 1
how do i setup BT homehub 6 with ASUS rt-ac66u
hi folks
I've a BT homehub 6 works ok, but i want to add my old Asus rt-ac66u to the BT homehub with the Asus being a "VPN port switch"
I want the BT homehub running as normal using say 3 of the LAN connections, and the ASUS connected to the BT Homehub and that would have 2 or 3 of the LANs used by devices that go though the VPN
I've read a few blogs, but still unsure how to do it
can i run bt homehub as 192.168.1.254 and Asus 192.168.1.20  ? or does Asus need to be on 192.168.2.1 etc
i've other questions, has anyone done this sort of thing is there any writeups ?
thanks
