vic1956
Message 1 of 8
hub 3 wireless dropping
the bt hub 3 has been dropping wireless speeds since January this year, getting worse as i have to reset/change wireless channel number frequently per day. Hub speed on wired coonection is very good - 70 mb/s; good wireless is 17 mb/s; slow wireless is 1-2 mb/s. Been on to bt help and after 1 week said they are not responsible for wireless speed, only the main wired speed. So after all that i have now done a factory reset on the back of the hub and will let you know the outcome....here's hoping!
7 REPLIES 7
Message 2 of 8
Re: hub 3 wireless dropping
vic1956
Message 3 of 8
after 6 hours i had to reset the wireless channel - so the factory reset did not change the above problems. Can bt send me a new hub?
Distinguished Guru
Message 4 of 8
What wireless channel are you now on?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
vic1956
Message 5 of 8
Channel 1 then speed dropped so now on 6
vic1956
Message 6 of 8
Yes similar - tried every combo but no better
Message 7 of 8
There are 13 channels in total, have you tried them all?
If they all fail, then read this post by BT
https://community.bt.com/t5/Other-Broadband-Queries/HH3-Infinity-Local-WiFi-Channel-fade/m-p/1455199...
vic1956
Message 8 of 8
Finally last to try was ch 13 - good speed lasted almost 24 hours but has now reverted to very slow ...nothing else left to alter
