thedantheman
Message 11 of 14
Re: hub password
Many thanks, I'll check it out but if some devices are and others are not, would that be an issue?
Anonymous
Not applicable
Message 12 of 14
Re: hub password
No
licquorice
Message 13 of 14
Re: hub password
There's not really any great advantage in connecting at 5Ghz. It is faster but has a shorter range than 2.4Ghz, however, the speed is only of use if you have a very high speed broadband connection or use a NAS to stream on your LAN.
thedantheman
Message 14 of 14
Re: hub password
Many thanks, everyone, I think I'll stay at 2.5 GHz for the moment as the gain is small
