spaceman
Message 1 of 3
Hi my first message.When I startup my laptop it automaticly connects to the hub.I know I can control that by switching off the hub,but can I control when I connect on my laptop?Thanks.
2 REPLIES 2
Message 2 of 3
Re: hub3
yes when you turn off your your laptop it you automatically disconnect from the internet you should never turn of the hub as that can cause broadband speed problems
spaceman
Message 3 of 3
Re: hub3
Thanks john46 I understand now.spaceman.
