asc14
Message 1 of 29
iPhone only won't connect to BT hub/wifi
I have BT Infinity with the latest hub. It works without any problems with my laptop, tablet and smart tv. However, it doesn't like my (or my wife's) iPhone. It's intermittent. Sometimes it will connect. Sometimes it won't. There seems to be no reason. WiFi assist is OFF on both iPhones. My data is going through the roof as such. Any suggestions?
Tags (1)
28 REPLIES 28
stevebrass
Expert
Message 2 of 29
Re: iPhone only won't connect to BT hub/wifi
have a look
Here
Message 3 of 29
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Some devices have a problem with the Homehub dual band having the same SSid (name). You should try splitting them as per the above post.
See link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
asc14
Message 4 of 29
Thanks for the help. I have now split each band and switched off "smart setup". The effect now is this - my wife's iphone 5S seems to have a more consistent connection to the 5GHz band. However, my iPhone 6 won't connect to either! Any further ideas?
Message 5 of 29
"Forget" any previous connections on your phone to the Smarthub.Restart the phone then try and re-connect.
asc14
Message 6 of 29
Still no joy. The phone has a tick next to the normal 2GHz hub but this won't display at the top of the phone and obviously won't work. My phone won't connect to the 5GHz one at all. It says incorrect password. It isn't. I've tried 10 times.
asc14
Message 7 of 29
on 11th attempt has now accepted the password. however, no joy
Message 8 of 29
asc14
Message 9 of 29
Now in mode 2. Same problem
asc14
Message 10 of 29
It's weird. There's a tick next to the hub in settings but it won't do anything
