Jamo1972
Message 21 of 29
Re: iPhone only won't connect to BT hub/wifi
Setting a static IP on the iPhone has seemingly done the trick for us. Thanks.
Poppy7
Message 22 of 29
It worked for us too with our Sky Box which stopped connecting after the latest firmware update. So I am wondering what is wrong with the Smart Hub that the only way to get a stable connection to it is to set up static IP addresses on some devices? So far our Apple devices are connecting but I haven't yet allowed them to update to iOS 10 in case there are problems.
Message 23 of 29
The DHCP server on the HH6 seems to be completely broken. It either doesn't allocate addresses or allocates duplicates.
djstevied
Message 24 of 29
I'm having the same problem with the iPhone 7.
This problem should of been fixed asap.
stevebrass
Expert
Message 25 of 29
Please mark as solved then to help future posters.
Message 26 of 29
@stevebrass
The original person who started this thread @asc14 has not returned, which is why its not been marked as solved.
Can you identify which post on this thread is the actual solution?
stevebrass
Expert
Message 27 of 29
Sorry - didn't notice that.
The solution (well a workaround really) is the Poppy7 post advising to use static IP.
Message 28 of 29
I have marked it as the solution in this case.
NigDig
Message 29 of 29
BT have delivered a new Smart Hub to replace a friends previous Home Hub, and two different iPhones (4 and 5s) will not connect.  Microsoft laptops and Windows phones connect just fine.  We have tried just about everything suggested on this discussion except static IP addresses.   Why is it that BT still dont seem to have got this fixed?
