j14l99
Message 1 of 3
iPhone suddenly cannot connect to wireless
So i have been having no problem connecting the wifi for more than a yr, but then just suudenly got disconnected and have problems trying to connect back as it keeps saying I got the wrong password (even if i got onto the Hub Manager and enter the password shown there).
try to forget the network and reconnect - not work
try to manually type in the SSID and select the appropiate security - not work
what should I do?
2 REPLIES 2
Message 2 of 3
Re: iPhone suddenly cannot connect to wireless
Try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. This can often sort out problems.
j14l99
Message 3 of 3
thanks for the help mate. literially just reset the hub itself and got it fix.... what an idoit i am..... but thanks mate
