shamus1
Expert
Message 1 of 15
ipv6
this has been active on my smarthub for a couple of weeks and now its disabled,its active in the router but it says ipv6 network disabled now any ideas?
14 REPLIES 14
smf22
Recognised Expert
Message 2 of 15
Re: ipv6
Is it the 'IPv6 network status' under Advanced settings -> IPv6 -> Status (http://192.168.1.249/0000012803/gui/#/ipv6/status) that shows as disabled? If so that would seem to suggest you're not connected to an IPv6 enabled BRAS.
Has the Hub reconnected the WAN PPPoE session recently?
shamus1
Expert
Message 3 of 15
Re: ipv6
yes it reconnected the WAN PPPoE 12 hrs ago but router uptime is 5 days
5 Days, 4 Hours 56 Minutes 15 Seconds.
Connection time:
0 Days, 12 Hours 42 Mins 44 Secs
smf22
Recognised Expert
Message 4 of 15
Re: ipv6
The BT statement in the ISP Review post stated rollout "was completed for “all BT Broadband lines” in October 2016 (except IPstream connections)". It would seem that when your line sync'd again it got load shared to a BRAS that is not enabled.
If you want IPv6 back I guess you could force a disconnect on your broadband connection from the Hub GUI and re-connect to see if you then get IPv6 enabled again.
Regards
shamus1
Expert
Message 5 of 15
Re: ipv6
yes just rebooted and its working again any ideas why it went funny?
shamus1
Expert
Message 6 of 15
Re: ipv6
my router now says firmware updated 25-Nov-2016 but was october before i just rebooted and still on same firmware after reboot SG4B10002236
shamus1
Expert
Message 7 of 15
Re: ipv6
logs now say after my reboot but firmware version is the same?
17:11:33, 25 Nov.
ppp1:TR69 event found : M Download
17:11:33, 25 Nov.
ppp1:TR69 event found : 7 TRANSFER COMPLETE
17:11:33, 25 Nov.
ppp1:TR69 event found : 4 VALUE CHANGE
17:11:32, 25 Nov.
ppp1:TR69 sending Inform message
17:11:32, 25 Nov.
17:11:32, 25 Nov.
17:11:32, 25 Nov.
17:11:30, 25 Nov.
17:11:30, 25 Nov.
ppp1:TR69 creating new session with ACS
17:11:25, 25 Nov.
:HTTP UserBasic login from 192.168.1.64 successfully
17:11:21, 25 Nov.
:The Modem successfully installed a firmware update
smf22
Recognised Expert
Message 8 of 15
Re: ipv6
Not really. I saw the same thing when I was using the Hub 6... sometimes I'd have IPv6 and other times not. I put it down to the fact the deployment was not complete as that was before the BT statement at the end of October.
It could be that there are still some BRAS out there not enabled and you were just unfortunate to connect to that.... and of course it cuold simply be yet another bug on the HH6.
Regards
shamus1
Expert
Message 9 of 15
Re: ipv6
just rebooted again and am now running firmware SG4B1000223E but fon is active again which it was not on previous firmware,here we go again another nightmare to get that switched off.
planetf1
Expert
Message 10 of 15
Re: ipv6
I'm on a HH5a & didn't have IPv6 enabled. Just rebooted the hub, no difference. I've never seen IPV6 sadly 😞 😞 😞
So are BT saying everyone/all lines SHOULD have access to it now? (in which case I'll raise a problem about it?)
