Message 1 of 2
link to order extra wifi discs broken
I'm having trouble with the online troubleshooter which you are directed to for ordering extra WiFi discs - it tests my connection but no option for ordering Discs and I don't have a spare hour to be on the 'phone to BT! Others seem to have successfully order through online Chat but I just get told to ring them - do I need to use specific words?
1 REPLY 1
Message 2 of 2
Re: link to order extra wifi discs broken
try contacting billing and see if they can help or connected you to someone that can - use message now
https://www.bt.com/help/contact-bt/account-and-billing/broadband
