gordo52
Message 1 of 3
modem to smart hub
Hi to everyone..   Due to be swiy=tched on this monday, just received the smart hub,   looking through the kit got me a little puzzled.
I have this modem  fitted .  my present connecton uses  and ethernet plug from the modem  to the plusnet  router.
a couple of questions,  how to connect modem to router and with what lead.
do I need the micro filter as it is a fibre optic connection
Sorry to be thicko  want to get it right on monday
2 REPLIES 2
Message 2 of 3
Re: modem to smart hub
You no longer need the white Openreach modem. You plug the Smarthub directly into your telephone socket. If it is a filtered master socket you do not need a filter.
See this guide.
BT Smarthub Set Up
gordo52
Message 3 of 3
many thanks my friend appreciated ..
