tjwhitehead
Message 1 of 3
moes wifi switch not connecting to BTSmartHub2
I am trying to connect a moes wifi switch through Smart Life app to the BTsmart hub 2.
I have tried:
Turning off 5Ghz so only 2.4 is available, changing SSID, disconnecting additional disks and it still can't find it.
any other suggestions?
2 REPLIES 2
imjolly
Message 2 of 3
Re: moes wifi switch not connecting to BTSmartHub2
Did you also turn off smart setup
tjwhitehead
Message 3 of 3
Thanks, did the trick!
