rio
Message 1 of 5
my Viera tv connects to router but not internet (server failure 007)
all of sudden cannot connect to Netflix BBC I players etc, is there a simple solution to this?
4 REPLIES 4
NigelB72
Guru
Message 2 of 5
Re: my Viera tv connects to router but not internet (server failure 007)
Smart TVs are not actually very smart at all and apps will stop working at the drop of a hat if the tv manufacturers don't update them. This happens all the time.
I'd suggest checking the user forums for your tv to see what the error code means and also if anyone else is having the issue.
I assume that Netflix etc work fine on other devices?
rio
Message 3 of 5
Thank you Nigel, yes I can access Netflix from my mobile.
I’ll try the user forum as you suggest
Carlusha
Recognised Expert
Message 4 of 5
Panasonic offer :
When connecting to the network an error, 007, appeared what can I do?
You will have to modify the Proxy settings you need to have Proxy (blank) and Proxy port (0).
rio
Message 5 of 5
Carlusha, you are a gem. Have done exactly as you said and it is working!! Thank you very much
