Message 11 of 48
Re: my laptop won't connect to smart hub 2 just says limited but connects to other laptop and mac
We have tried the reset,disabling the smart set up and switching off the5Ghz setting but still won't work. The laptop says it is connected but I can't get on the internet and email says it is not connected to the internet. Ran a troubleshoot and network adaptor says the default gateway is not available.
Other fault says windows could not automatically detect this networks proxy settings.
The network adaptor is Broadcom 802.11n
Windows 6.3
Laptop worked perfectly well with the old hub so what is wrong ??
Any help gratefully received
Message 12 of 48
Change the wireless mode to Mode 3 in wireless advanced settings.
Message 13 of 48
Sorry to sound silly but is this on the hub manager
Message 14 of 48
Yes, same screen where you turned off 5Ghz.
Message 15 of 48
And leave the 5GHz switched off
Message 16 of 48
Message 17 of 48
No that has made it worse
Recognised Expert
Message 18 of 48
Whilst your connected to the hub manager, goto Advanced Settings and My Network.
Boot the device your having problems with, can you see the device you're having problems with in the list of connected devices, if so, is the background colour green or grey and finally are there any warning icons alongside it
Message 19 of 48
My PC is green with the letter D we turned mode back to 1 as the PC couldnt find the hub. What is odd is it says it is connected but internet etc says not
Message 20 of 48
You have wireless connectivity but clearly not getting an IP address from the hub for some reason. Try disabling and then re-enabling your network adaptor.
