Message 41 of 48
Re: my laptop won't connect to smart hub 2 just says limited but connects to other laptop and mac
Is there a reason why we can't change back to the old hub as now on fibre
Message 42 of 48
He called it a WI Fi router is that the same thing?
Message 43 of 48
If your old hub is a Hub 5 or later, then no reason at all. If it is a Hub4 or earlier, it won't work with fibre.
Message 44 of 48
No, that is what the hub is, not sure what the intention is. If it is to replace the wifi adaptor on your laptop, you just need a dongle.
Message 45 of 48
Yes I think that's what he means, just seem to be going round in circles now
Message 46 of 48
The old one was a hub 3. Do you think the settings are different and that's why the new one is struggling with my computer?
Recognised Expert
Message 47 of 48
Did you enable those options in message 31?
You may need to reboot for them to take affect.
Message 48 of 48
Thanks for everyone's help but we solved in the end by using a wireless USB adaptor an Archer T4U, apparently the broadband changes over on the 19th May not the 1st as originally suggested so hoping that won't cause any more problems..
