paulpa66
Message 1 of 4
problem with port forwarding
I have used port forwarding with noip for security cameras but just recently i can't access the router or cameras i just get a ERR_CONNECTION_TIMED_OUT. if i try to check the port on  an open port check   i get the port is open
but still can't access, noip is updated to see my ip ok
have rebooted router but still can't get any joy?
3 REPLIES 3
V_Meldrew
Recognised Expert
Message 2 of 4
Re: problem with port forwarding
Can you view the camera over your local network? if not then reboot your camera
paulpa66
Message 3 of 4
Hi yes i can. It now works I have turned on dynamic dns to update noip of my ip think this was the issue
V_Meldrew
Recognised Expert
Message 4 of 4
Some IP cameras come with a free ddns service but if yours doesn't, or if it does but it's not enabled, then that probably was the cause
