haybie
Message 11 of 26
Re: "Your connection is not private NET::ERR_CERT_AUTHORITY_INVALID"
Hey @RobbieMac ,
thanks for the advice. yes, the phone line support did mention this charge, The engineer came out did the test and changed the master socket on the wall and did extensive testing using the test socket.
I thought @NeilO was helping me through the process at the moment.  Why do I need to send my personal details to you to be contacted another team member? is it a different procedure?
Many thanks,
Haybie
DavidM
Moderator
Moderator
Message 12 of 26
Hi @haybie  and thanks for posting.
I'm sorry for any confusion here. Once you send over the details one of the moderators (we're a small team) will pick up and case manage until everything is resolved.
Cheers
David
NeilO
Moderator
Moderator
Message 13 of 26
@haybie The moderators work in shifts, I had finished working on the community yesterday afternoon and @RobbieMac took over for the evening.  If you send over your details following @RobbieMac's instructions we'll be happy to help.
haybie
Message 14 of 26
@NeilO
OKay, many thanks for your help.
I sent my details via the private message.
@RobbieMac
thanks,
Haybie
RobbieMac
Moderator
Moderator
Message 15 of 26
You're welcome @haybie
When we get your details we'll take it from there.
Cheers,
Robbie
DanielS
Moderator
Moderator
Message 16 of 26
Hi @haybie,
Thanks for taking the time to speak with me today.
I will be in the office on Wednesday until 4pm. Feel free to post up after the engineer has called.
DanielS
haybie
Message 17 of 26
Hi @DanielS
The Engineer came today. Unfortunately, he wasn't a broadband engineer and was surprised he was sent.
He did all the checks on the line and found no problem. He did the quiet test and said it was completely fine.
The only thing he was able to do was reset the card as it was set to only 55mbs and maybe creating the dropouts.
However, since he left it has dropped out a few times still. I am hoping it is only temporary. I will keep an eye on it and see if there is any improvement and let you know.
Many thanks,
Haybie
Kvass20
Message 18 of 26
Same keeps happening to me too! Normally when says connection not private its went offline. When I switched like you was fine for couple weeks then we had about a month of constant on/off. Was fine for about a year now it's gone off every sat for the past three days! Everytime I complain about it or go through the broadband test it miraculously comes on again! Really annoying
DanielS
Moderator
Moderator
Message 19 of 26
Hi @haybie,
I'm sorry to hear that you have had a few drop outs since. The first engineer that went out was for broadband. As they couldn't fine an issue we looked at your line. As you advised that the line was noisy, without the Hub connected, I agreed to send an engineer out to test the line to find the source of the interference.
I will be out of the office both tomorrow and also now on Friday. I will be here over the weekend though and I will happily help you if needed.
DanielS
haybie
Message 20 of 26
@Kvass20
So did it go away eventually?
