bob46
Newbie
Message 1 of 16
remotely find my ip address
Hi
can someone help please, I remotely access a security camera on my network, through a DNS service with Dynu systems, this works ok, but they are not listed in my Home Hub 4, so i am not able to set an auto update of my ip address, i have not found a way to update the list, so i need a way to find my ip address, if it changes when i am away.
Any idea's
Robert
15 REPLIES 15
Message 2 of 16
Re: remotely find my ip address
Have you checked to see if your camera has its own DDNS service built in, as the normally do?
Message 3 of 16
There is no way to find your IP address remotely. Can you not either add your dynamic DNS service to the HH4 or use one of the listed services?
bob46
Newbie
Message 4 of 16
Keith
I made the security camera using a Raspberry Pi, so no service included
bob46
Newbie
Message 5 of 16
Licquorice
Is there a way to add my DNS service, it is not in the list, and i have not found how it can be added ?
Message 6 of 16
Sorry, I'm not familiar with the workings of a HH4 but there should be a way to add Dynamic DNS services, hopefully somebody else will be along that has a HH4.
Does this thread help ? https://community.bt.com/t5/Home-setup-Wi-Fi-network/BT-Home-Hub-4-Nowhere-to-enter-DDNS-service-Det...
bob46
Newbie
Message 7 of 16
Thanks Licquorice
I did find that thread, but it looks like there is a set list of DNS  services to select from, and no way to add your own, that i have found, so far.
Message 8 of 16
Might be simpler to just get a third party router that doesn't restrict the services available.
bob46
Newbie
Message 9 of 16
thought about it, annoying you have to do that, rather than update a list !
Message 10 of 16
