dajo4
Message 1 of 7
setting up a linkseys router to access my hub3
when it comes to inputting my wireless key I get a key missmatch
Help please
6 REPLIES 6
Message 2 of 7
Re: setting up a linkseys router to access my hub3
Help please
You will have to be more specific about what you are trying to do. The home hub 3 is a router, so why would you want to plug in another one?
dajo4
Message 3 of 7
thanks Keith,
I use a netgear adapter in my desktop computer in another room from the hub, I thought that by using the Linksys I would get a better connection !! I get the key missmatch trying to connect
Message 4 of 7
You cannot connect two routers to your broadband line. How is the Linksys connected to the home hub?
dajo4
Message 5 of 7
keith
it would connect by wireless. but if I cannot connect two routers then thats the answer
many thanks
Message 6 of 7
I think I can see what you are trying to do. You cannot use a wireless router to connect wirelessly to the home hub, as its a wireless access point and not a client.
If its a general networking issue that you are trying to solve, then there are some suggestions here.
Network connection problems and possible solutions
dajo4
Message 7 of 7
keith many thanks I will try what you suggest
dajo4
