Message 1 of 5
slow connection detected error
Month ago changed to `infinity`and cannot say have noticed the slightest improvement in speed of anything.
An error message flashed up saying `we have detected slow connection between hub and vision box`
Two questions:
1/ What the Hell does that mean and what could I do about it?
2/ Why has everything, and I mean everything, to do with BT (including getting into this forum) have to be so long winded, complicated and sufficient to try the patience of a Saint?
4 REPLIES 4
Message 2 of 5
Re: slow connection detected error
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Message 3 of 5
Managed to get the stats (below) but speed tester incomprehensible
Product name:
BT Hub 6A
Serial number:
+084319+NQ63449920
Firmware version:
SG4B10002244
Firmware updated:
16-Dec-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:  0 Days, 2 Hours 14 Minutes 55 Seconds
Data rate:
13.61 kbps / 69.04 kbps
Maximum data rate:
13611 / 67606
Noise margin:
6.2 / 6
Line attenuation:
20.7
Signal attenuation:
0 / 207
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
13 MB Uploaded / 82 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-R56X
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-R56X
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:20:07:BD
Software variant:
Boot loader:
7.33.1
Message 4 of 5
You are connected at 69Mbs, so there is nothing wrong with that.
Why is the speed test incomprehensible?
Are you using this link http://speedtest.btwholesale.com/
How is the home hub connected to the BT YouView box?
Message 5 of 5
Computer (a tower variety) is remote from hub, no wired connection available and if there were am not sure fully understand all of the other necessities.
Hub is on a shelf below vision box, cable used is perhaps a bit longer than needed (less than a metre would do). It was an old cable from previous set up and am wondering if that may need updating or something, if so what spec?
