floss21
Message 1 of 2
slow wifi
I have noticed ...To type in the speed test page on the internet ,you have to have a speed fast enough to not get the reply back ....you have been timed out...in other words .you have to have speed to check on speed on site ,which is very frustrating .WHAT  is the point ....trying to check the speed if your internet speed is that slow you cannot get to the speed not to be timed out due to lack of speed  ?????
1 REPLY 1
Techwizz
Message 2 of 2
Re: slow wifi
Hi @floss21,
Which speed test site are you using? Are you trying to conduct the speed test over WiFi or through a wired connection? Which router are you using?
