Message 1 of 2
smart hub 2 connecting to udmpro to keep voice service
hi
I have been sent a smart hub 2 in preperation to get voice over the fftp fibrer .
at present my UDM PRO is connected without the smart hub ,but i will require to have the smart hub2 connected before the UDM PRO , is there a way to cofigure the smarthub 2 as through connection and keep the UDM PRO to do the routing. any help appreciated
1 REPLY 1
Message 2 of 2
Re: smart hub 2 connecting to udmpro to keep voice service
You can bodge it by connecting the 2 devices together but both will be routing and natting
Even if you could put the hub in modem, it would be pointless as there wouldn't be access to the IP layer for VoIP.
