craigbagua71
Message 1 of 7
smart hub disc
followed the plug in instructions etc... but keeps defaulting to red any suggestions?
6 REPLIES 6
albertj
Recognised Expert
Message 2 of 7
Re: smart hub disc
Hi @craigbagua71
Welcome to the Community!
Sorry to hear about the issues you're having.
How are you connecting the disk to your Smart Hub? Ethernet, WPS or the App?
Have you got the black disks? Are you paying for Complete Wi-Fi or purchased the black disks separately?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
craigbagua71
Message 3 of 7
Re: smart hub disc
hi I plugged in with supplied cable initially waited until it turned solid blue, then removed the cable, it flashed red for a bit then changed to solid blue. I then unplugged disc and relocated to where I wanted it then it just kept flashing red. I think it may be easier to factory reset it as the WPS button didn't work either
Keith_Beddoe
Message 4 of 7
Re: smart hub disc
@craigbagua71
@albertj  asked you what colour is the disk itself, black or white?
craigbagua71
Message 5 of 7
Re: smart hub disc
its black
Keith_Beddoe
Message 6 of 7
Re: smart hub disc
@craigbagua71 wrote:
You should have received an install guide with your new smart hub 2 and black disc.
Instructions are in there, including detail for downloading the correct MyBT app, and how to install your disc (it doesn't need to be connected to the hub).
Perhaps you are using the wrong app?.
I assume you have the smart hub 2?
craigbagua71
Message 7 of 7
Re: smart hub disc
right ok cheers engineer set it up originally ill see about the app thing
