hixopupo
Message 1 of 2
smart hub randomly reboots
Hi wonder if someone can help me,
My smart hub randomly reboots, it can (I think) go for several days with no problem, & then it will re boot, sometimes once or twice, sometimes over & over again for up to 45 mins, I can reconnect for a few moments as it completes but (of course) am disconnected as it reboots.
Thanks for any help that can be offered
1 REPLY 1
imjolly
Message 2 of 2
Re: smart hub randomly reboots
check your landline for noise  dial 17070 option 2  should be silent and best with corded phone
if no noise then try factory reset of hub by pressing recessed button on back and holding 20/30 secs until light flash  when reboots remember to turn off smart setup
