coldfire
Newbie
Message 1 of 3
stop new devices connecting automatically to home hub
is there anyway to configure the home hub to require authentication when a new device connects to it.
example - somone gets wifi key from the router and connects.
the way i would like it is - somone gets wifi key from the router and connects, router then needs the admin to accept that connection in the settings page
2 REPLIES 2
Message 2 of 3
Re: stop new devices connecting automatically to home hub
Not possible I m afraid
Message 3 of 3
If you are trying to set up some sort of control for "guests" or to control family members from using the Internet you will need to purchase a better VDSL Modem/router than the Homehubs.There are third party routers that will allow you to do that.
