selwoc
Newbie
Message 1 of 4
streaming
can anybody tell me how much usage to stream a live rugby match.
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: streaming
It's variable and hard to find a precise figure, but published estimates suggest you should think 500MB-1GB at standard definition.
spencert
Message 3 of 4
Re: streaming
I found this BW calculator site. You might want to try this.
http://www.netromedia.com/pricing/calculators.aspx
selwoc
Newbie
Message 4 of 4
Re: streaming
cheers, didn't realise it was that much, was told it was very little. glad i checked it
