Hi Guys,
I am sure one of you learned specialists can answer my question i am stuck on.
Currently I have my DECT phone master plugged into the back of the Smart Hub2 on fibre900 which works fine, but if I change out the smart hub 2 for the Asus WiFi 6 what do I need to buy or do to connect my DECT phone master as none of the better routers have a phone port ?
Appreciate any help or advice on this
You can only use the Smart Hub 2 for the digital voice service, no other routers can be used with this service.
@garycpos wrote:
So the only solution would be to get a landline fitted ? I have the full fibre modem installed under the stairs with what looks like a phone lead coming off with a RJ 11 connector on it ?(New House Build)
Is there any other solution available in your mind if I use the Asus WiFi 6 router ?
That would be a FVA (Fibre Voice Access) which is no longer available, as it been replaced by BT Digital Voice which uses the Smart Hub 2.
Unless there is also a copper connection coming into the house, which is unlikely now on new builds, you have no other option.
Why do you want to use a different router?
If its a wireless mesh solution you are looking for, then the BT Complete Wifi solution uses the smart hub 2 as the first node in the mesh, which consists of the black disks provided as part of the package.
The other option is to use a mesh system that can work in AP mode, and you then turn of the wifi on the home hub.
Systems like the Tenda Nova MW6 can do that.
