sunshine12
Message 1 of 23
using third party router
Can I use a third party router with my superfast fiber broadband?
22 REPLIES 22
Keith_Beddoe
Message 2 of 23
Re: using third party router
Welcome to this user forum.
Yes, provided its a VDSL modem/router and not just a router.
Here are a couple of suggestions, there are others, but I would ask here first, to save wasting your money.
TP-Link AC1200 Wireless Dual Band VDSL/ADSL about £67
https://www.tp-link.com/uk/products/details/cat-15_Archer-VR400.html#specifications
If you only want single band wireless, then this one.
The TP-Link TD-W9970 for about £40 or less.
https://www.tp-link.com/uk/products/details/cat-15_TD-W9970.html#specifications
They both work will all BT services, including BT YouView.
sunshine12
Message 3 of 23
so do i have to put the smarthub into modem mode to be able to use a seperate router?
also i found this router will it be compatible? "ASUS RT-AC86U Wi-Fi AC2900"
Keith_Beddoe
Message 4 of 23
No, the smart hub cannot be put into modem only mode.
If you wanted to use that ASUS router, you would also have to purchase a separate modem, at extra expense.
The Asus DSL-AC68U would work, as that is the correct one, but expensive.
https://www.asus.com/uk/Networking/DSLAC68U/
Not sure if it will work with BT YouView, if you have it.
You may get other suggestions on this forum.
sunshine12
Message 5 of 23
no i dont want to have to use anything else other than a router of my choice.
so your saying i can't use  "ASUS RT-AC86U Wi-Fi AC2900" unless i buy a seperate modem?
Also this one you suggested ARCHER VR400 AC1200, will work and i wont need anything else, to make it work?
sunshine12
Message 6 of 23
using seperate router help please
TP-Link AC2800 Dual Band Wireless MU-MIMO Gigabit VDSL/ADSL Modem Router for Phone Line Connections
will that router work with superfast fiber? WIll I have to use a modem for it? OR is it plug and play?
Keith_Beddoe
Message 7 of 23
Re: using seperate router help please
It should be fine. Most TP Link routers are plug and play.
There is an emulator on this page https://emulator.tp-link.com/VR2800V1_Emulator_2017042605/index.htm
TimCurtis
Guru
Message 8 of 23
Just to say that the mentioned Asus DSL-AC68U modem/router is very compatible with BT TV as well as offering very strong wifi.
Another advantage could be it's ability to transmit BT's internet channels over wifi if physical connection to a Youview box is difficult.
philbern
Message 9 of 23
Hi.. I'm looking for recs for a router to replace my HH6 that will work with BT TV and can also accommodate a vpn for IPTV on my smart TV please.
Keith_Beddoe
Message 10 of 23
Then use the one @TimCurtis  recommended. Asus DSL-AC68U
It says VPN server and client support
Remotely access your home network through encrypted and private connection
Enablea VPN server or VPN client with DSL-AC68U for encrypted
remote connection
If that is what you are looking for?
