qwerty1231
Newbie
Message 1 of 2
is there any way you can set up the router (hub6) so i can use vpn on my samsung tv.
1 REPLY 1
Message 2 of 2
Re: vpn
The BT routers all support the use of a VPN which is installed on the device you are using  but I doubt there will be any way to set up a VPN client directly on any of the BT routers.
You would need to get a third party VDSL Modem/router that supports a VPN client either already installed in the router's firmware or one that will allow a VPN to be installed on the router.
