licquorice
Message 11 of 15
Re: where have I gone wrong.
It just means you can't access your internal addresses via your external address from an internal address if that makes sense. You need to try accessing your application via a 4G signal, or from elsewhere.
Leehebrides
Message 12 of 15
NAT loopback,  right I can access the server fine on my internal IP address whilst at home say on my ip, by its internal lp address , so to check if I can access it from out side I needed to use 4 g or maybe BT wifi with fon ?
licquorice
Message 13 of 15
Yep
Leehebrides
Message 14 of 15
Thanks, I am off to another island tomorrow I try from there via 4 g
Leehebrides
Message 15 of 15
tried yesterday by 4g and hospital wi-fi can not connect. back to square one. I might try one of the other Staic Ip providers see if it works with another service like Dyndns
